Remade some of the C03-24 rudder cable adjusters for a better rudder pedal alignment and nose wheel alignment.
Prime painted the instrument panel with Stewart EkoPrime E7520. I tried to spray it using a Preval disposable spray gun without much luck. With the primer diluted 10% per instructions for spraying, the gun seemed to clog up. Ended up bushing on the primer. It leveled itself out very well.
Finished removing the engine mount and tri-gear to prepare the firewall.
Started installing grease fittng in the nose gear bushings. The fitting will also replace the set screw normally used to retain the nose gear bushing.
